Lathe Cam Stock Offset turning
CNC4XR7
Message 1 of 12
CNC4XR7
Hello
I have searched through the posts but cant seem to find a answer for my issue forgive me if it has been covered elsewher.
I would like to bore a bearing pocket in a 4" x 3" stock 2" from the top so the pocket will be off center.
Is there a way to tell 360 where the Z axis centerline is located in relation to the stock?
Replies (11)
Message 2 of 12
skidsolo
I think this is what you are asking for, just edit the setup and choose the origin as "selected point" the pick the hole.Screen Shot 2016-03-22 at 9.42.26 AM.png
Andrew W. Software engineer (CAM Post Processors)
Message 3 of 12
CNC4XR7
I don't have those options avalible in a turning setup.
Be Safe,
Sam
https://www.youtube.com/user/CNC4XR7
Message 4 of 12
HughesTooling
You should have these options.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 5 of 12
Mark,
Can you actually get Fusion to generate a toolpath for this though?  I played around with it the other day when the question was first asked and couldn't get it to work.
I started with a drilling operation which worked fine, but the inside profile did not seem to know how to act at all.  A the graphic displayed for the radius settings was shown far from the part itself.
Dave
Message 6 of 12
HughesTooling
I found I needed to set the X axis pointing in the direction below then it worked.
Got the error about crossing the rotary axis though, you need to have a through hole to get rid of the error.
File attached with through hole to stop error.
Mark
Mark Hughes
Message 7 of 12
Interesting... I hope the original poster doesn't mind me posting this here.  When I first tried this, I don't think they had posted their part so I just drew up a rectangular part with an off center hole and tried to do an internal profile.  I just looked at it again and can't get it to work at all.  And if I try to set  the X axis to one of the edges it rotates it about 45 degrees from that edge.
Is it just me?
Dave
Message 8 of 12
HughesTooling
There's something odd with your file, I've seen it before and I din't know what happens but it seems like the CAM is working to the wrong scale so you end up with this odd display.
I found I needed to make the tolerance 0.001 for the spun profile to work. I managed to get it to work by entering sizes on the radii tab, file attached.
Mark
Mark Hughes
Message 9 of 12
HughesTooling
Is it just me?
Dave
I don't know what's going on with your file, I made it into a component and copied into another file but it still doesn't want to work. So I made another file from scratch and it worked first time.
File attached.
Mark
Mark Hughes
Message 10 of 12
CNC4XR7
Thanks Mark
Man I thought for sure I had clicked on every option for the life of me I could not figure out why I could not get it to work out.
Many thanks.
I originally saw your first repley on  y phone so I did not receive the pictures.
Those help alot thank you very much I still have a lot to learn.
Be Safe Sam
Mark
Message 11 of 12
CNC4XR7
Thats the exact same issue I had LOL. Marks solution worked and you need to check spun profile as well
Sam
Message 12 of 12
HughesTooling
Is it just me?
Dave
@Anonymous I played with your file a bit more and got it working by rotating it in the model work space so the hole is around the Z axis like this.
Why it should make any difference I don't know, the orientation of the model should not matter. I wonder if it's to do with the spun profile as I've not had any problems with parts that aren't around the Z axis before.
Mark
I've attached the file. I made the part into a component then rotated, I had to delete the set up as it would not work after rotating the part,
Mark Hughes
