First time running fusion in a month or so. I'm no longer able to generate tool paths. I get a kernel error. Last time i ran the program this was a fully working toolpath-- i've made no change to the file. Using this as an example since i'm not able to generate any paths. Fusion did install an update since my last use. Any suggestions?
Feature flags: setup-sheet-viewer
Debug: Initialization elapsed time: 0 ms
Debug: Writing ironjob to C:\Users\Josh\AppData\Local\Temp\Fusion360CAM\3312-2\operation6.ironjob
Debug: Writing jobfile to C:\Users\Josh\AppData\Local\Temp\Fusion360CAM\3312-2\operation6.hsm-job
Debug: Using CAM kernel from: C:\Users\Josh\AppData\Local\Autodesk\webdeploy\production\50d1a2b00ac928c7781cbca6551e586a5384d498\Applications\CAM360\camkernel.exe
Error: Internal CAM kernel error. Please report through your support channel.
Debug:
Debug: Total processing time: 46 ms
Debug: Total elapsed time: 108 ms
Solved by seth.madore. Go to Solution.
I'm betting that you are running on Windows 7? This is an unsupported operating system. There is a temporary workaround HERE
The best solution is to upgrade to Windows 10. Otherwise, you are going to have to do this workaround each time Fusion updates.
Thanks for the reply. Little frustrating, but I'm working on migrating my CNC router over to a windows 10 PC now.
