Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Isolated 3D Profile Area
15 REPLIES 15
Message 1 of 16
1129 Views, 15 Replies
I am making a snail puzzle with an eye that is a spherical shape cut in with  a fillet around its perimeter.  The snail mouth is a groove cut in with a ball cutter and a fillet around the top surface.
All the other features are being cut out with 2d profiling tool paths.
All attempts end up getting the pupil cut out but none of the lead in profiling.
So how do I profile the areas leading into the eye and the mouth groove?
15 REPLIES 15
Message 2 of 16
HughesTooling
Have you attached the correct image?
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 16
A revised, cropped screen shot
Message 4 of 16
in reply to: HughesTooling
I cropped it a bit
Thank you for your help.
Allan Steinkuhl
Message 5 of 16
HughesTooling
Have you tried Selection as the machining boundary, and try Tool Containment set to center. You can select an inner and outer boundary if needed.
Mark
Edit You might have the heights set wrong, I think you'll have to upload the model as it could be a few things. From the file menu select export then set the file type to f3d and save to my computer then attach to this thread.
Mark Hughes
Message 6 of 16
Mark,
I more than likely have a simple issue.
I am picking Pocket Clearing as the mode of cutting my surface
I selected the tangent curve at the intersection of the fillet and the main surface of the snail face as my boundary.  It is not allowing me to box around the region.I then select Model Surfaces inside the region.I am getting an error that says the top needs to be above the bottom.  Sounds like I am dressing an infant but that may be my issue.When I go through the tabs and click the ok at the end, it drops off and compiles for several seconds and then gives me the warning it has not tool path to follow.
Allan Steinkuhl
Message 7 of 16
Laurens-3DTechDraw
If it says it has no toolpath your problem is probably the minimum ramp diameter.
Since I bet the ramping is set to helix in(Last tab.).
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 8 of 16
HughesTooling
Can you export the file and attach it will be something very easy to show you if I have the file. Go to the file menu select export set the file type to f3d and check save to my computer then attach to this thread.
Thanks Mark
Mark Hughes
Message 9 of 16
Mark,
I just received a hit from the blog that said my ramp was set to helix.
Here is my file, I will check the ramp in.
Allan Steinkuhl
Message 10 of 16
HughesTooling
There's no attachment.
Thanks Mark
Mark Hughes
Message 11 of 16
Thanks Mark
The e-mails suggest you can reply by e-mail and attach things but that doesn't work for some reason.
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 12 of 16
I had been attaching it to the responding emails. Here it is attached directly to a reply
Allan Steinkuhl
Message 13 of 16
HughesTooling
A few problems.
First your stock size is wrong and as it's too thin there's nothing for the 3d op to machine.
To fix this select the stock you've made a componant for.
In the op uncheck the Model tick box and set containment to centre.
File attached.
Mark
Mark Hughes
Message 14 of 16
HughesTooling
Also don't use the Model in the op to select surfaces you want to machine.
Either use a containment Boundary or use Avoid\Touch Surfaces.
Mark
Mark Hughes
Message 15 of 16
Mark,
I put a construction border around the cut and select that as a boundary.  I think my issue was back on the last tab it talks about stock left for finish.  That value was larger than the cut. So it was not cutting.
Allan Steinkuhl
Message 16 of 16
in reply to: Laurens-3DTechDraw
Laurens,
Yes the helical pick for bit entrance was selected.  I changed it to plunge and continued.  I believe my issue was  the pick where is asks for stock remaining for finish.
That value was larger than the cut I was attempting to make.  Therefore it would not take the cut.
Thank you
Allan Steinkuhl
