Fusion Manufacture
Is it possible to use if statements in CAM expressions?
2 REPLIES 2
FrodoLoggins
456 Views, 2 Replies
I want to make a roughing template that applies to 5 ZrN end mills (.5", .375", .25", etc.). I'd like the feedrate to update based off which tool I select.
Perfect world, I'd like to base the feedrate off the stepover percentage but I don't think that's possible.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
2 REPLIES 2
jeff.pek
in reply to: FrodoLoggins
Hi -
Yes, you can have simple conditions in your expressions. Here's an example:
tool_type == 'drill' ? 4 * tool_diameter : 2 * tool_diameter
This means "if tool_type is 'drill' then use 4 times tool_diameter, otherwise use 2 times tool_diameter.
You can use parentheses and AND (&&) and OR (||) in your expression, and even nest them:
(x == 4 || x == 7) ? 16 : (x < 2 ? 7 : 13)
Jeff
in reply to: jeff.pek
Check out this video for some examples of more advanced logic in CAM.
https://www.youtube.com/watch?v=dFSekpMbCdo
