Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Is it possible to create toolpath operations using the API?
7 REPLIES 7
Message 1 of 8
anthony.a.douglas
478 Views, 7 Replies
Is it possible to create e. a 3d toolpath operations with e.g. surfaces as model input using the API?  I looked through the documentation but cannot tell.  I was going to get in there and try it by treating a (toolpath) Operation object a bit like an ExtrudeFeature object to see if I could get one to create, but I don't think I will have a second to spare any time soon to do that ๐Ÿ˜ž (I hardly know any python etc. to begin with so even just to try it with reliability would take me a long time) so I thought I would ask.
It seems to be implied that it is not possible from the cam section of the api documentation, but the implication is vague and from 2016 so I gotta ask.
7 REPLIES 7
Message 2 of 8
No, this is not possible at this time, sorry...
Seth Madore
Message 3 of 8
Can I modify existing ones? Changing which surfaces they use as the model geometry, for instance.
Message 4 of 8
Sorry, no. The API hasn't been forgotten or abandoned, it's just been put on a sideburner for a bit ๐Ÿ˜ž
Seth Madore
Message 5 of 8
jeff.pek
in reply to: seth.madore
We do have an active effort that is underway to extend the API. Being able to create operations (from templates) and also setting geometry references are part of the expected enhancements.
Jeff
Message 6 of 8
Is there a schedule when this feature will be available?
Message 7 of 8
Hi - It's possible today to create new operation(s) from a saved template. This is in the adsk.cam.Setup object: createFromTemplate.
It's not yet possible to set geometry references from the API, though this is in our roadmap to add. Can't give you a specific timeframe for that.
Jeff
Message 8 of 8
I think it might be available now. Check the document that maps the API.
It said show it, if it is up to date.
