Hello!
All of a sudden I cant seem to create any new toolpaths!
Use Fusion 360 everyday, everything was fine yesterday, but as of this morning nothing seems to work, even very basic stuff.
Even copying a toolpath and making small adjustments has the same outcome.
Here is a small section of an error message, the same tool is used in other parts of the job no problem.
Invalidated: Tool
Invalidated: Tool
Invalidated: Invalidation due to different value for parameter 'tool_type' with level 7.
Invalidation due to different value for parameter 'tool_number' with level 2.
Invalidation due to different value for parameter 'tool_diameterOffset' with level 2.
Anyone else having similar issues? I don't think I am doing anything different to normal!
Solved by seth.madore. Go to Solution.
Can you share your Fusion file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Hi Seth, thanks for the speedy reply!
Can I PM it to you? Don't want to post a customer part on the forum if I don't have to!!
Email it to me: seth dot madore at autodesk dot com
Reference this thread so I will know the context 🙂
Also, I just tried it on 3 completeyl different parts, all seem to have the same problem
Should I still send it even tho it's doing it on every different part I try?
Also, same problem even on a brand new, super simple model with new tools etc
Is it possible you have any non-ascii characters in the tool name? Such as the degree or diameter symbol, õ, or any such non-english text?
Yes please. Also, Fusion has a ScreenCast option, could you use it to show me what you're seeing?
Are you on Mac or PC?
I'm not seeing a ScreenCast....
I did receive your sample file, but it regenerated fine. What happens when you select the Setup and CTRL+G?
Went back into work and it all seems to be up and running.
Thanks for your help!
