Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Invalid g-code: ID-33
2 REPLIES 2
rondon1
232 Views, 2 Replies
Error 33 question:
I am carving the back of a long neck through guitar neck. Everything seems fine in Fusion, however I am getting two error 33 on two of the lines  when I verify the job with Gsender. I've read some older posts but I can't even find those options in Fusion anymore, I am using Gsender and GRBL.
Any help is appreciated, I read some have had luck switching to millimeters, I am not sure where exactly will have to be changed to millimeters, some have change the actual gcode before is produced by Fusion. As far as I know the error has to do with arcs and the calculation to create them. Thank you!
Labels (1)
2 REPLIES 2
seth.madore
in reply to: rondon1
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
rondon1
in reply to: seth.madore
