After last update I started to run into problems with Internal CAM kernel error.
I had this with one of my turning projects, so I said i'll do some other work but than i ran into same thing in another project.
I'm uploading my current project as this error message isn't communicating what i'm doing wrong, just
"Internal CAM kernel error. Please report through your support channel."
this happens only at rough or finish turning operation. When i use old "turning profile" operation everything is ok.
I had no similar problem in earlier update.
After flipping through all the settings and playing with it a bit, it seems that the unequal Leave Allowance is what's throwing it off. If you set both X and Z to .5, it succeeds. Can you use that as a workaround? Obviously there's something going on, and half a MM is a fair amount of material....
Hi, @seth.madore
i've seen patchnotes and went to do some testing. Unfortunately there are still some problems with those operations.
See attached file.
if i set the roughing operations to start at 0 diameter it works with uneven allowance, but if I set it from 100mm diameter it still bugs out with kernel error. With even X and Z alowance it works normally.
Hi, @seth.madore
See attached file.
I always start turning with sketch of sectional view, make model by revolving it around Z axis, having fillets, chamfers and tolerances in sink with print. Later, if I have to use sketch to define cut,.... I can.
I do the same with customer supplied models.
I am not making case for basing turning on sketch or model exclusively, for now, it looks like we need both and one way or another I have to make parts.
huh thats even more bizzare that it works if you pick contour manually. Thefinitely there is something weird in the code.
But I don't understand that picture on the left. i don't see that line either on my example or in your file.
Picture on the left is my attempt to pick sketched lines from your file, marked line is part of flange sketch which I corrected on my file and that's why you don't see it there.
Sketch of a part sectional view must be one continuous and closed loop, no cross lies between outside and inside dimensions.
