I am trying to figure out how to do more intricate scroll work with my 90 degree chamfer mill. I get an internal cam kernel error every time I try and regenerate tool paths.
Nick
Solved by Steinwerks. Go to Solution.
This is due to your geometry selections. You have a lot of them and some are open to boot, so the kernel doesn't know what to do with it. If you simply select one closed chain it generates successfully:
