Fusion Manufacture
Inserting clamping devices takes too long
12 REPLIES 12
Message 1 of 13
iros102
784 Views, 12 Replies
I am having difficulties inserting clamping devices into my Fusion 360 project.
For example, I want to mill a turned part in a three-jaw chuck. I have created the chuck as a 3D model in Fusion and set up multiple joints so that all 3 jaws can move simultaneously.
The process goes like this: First, I add the three-jaw chuck, then the clamping jaws, spacer blocks, etc. Then I assemble everything and create connections.
The problem is that it is very cumbersome each time to position and connect the chuck with the appropriate clamping jaws and workpiece correctly.
Is there a simpler way to do this? How do you deal with this?
12 REPLIES 12
Message 2 of 13
Don.Cyr
in reply to: iros102
Look up how to setup a parametric vise, it's not exactly the same, but will show how to setup a joint origin to locate it on the stock and give some ideas on set the jaws based on stock size with parameters.
Please click "Accept Solution" if I helped with your question or issue.
Message 3 of 13
programming2C78B
I model the chuck in its own file, with joints and any bases. I then insert it into my part, break the link, and join it on center as needed. You can then move the jaws to match your OD, or edit the Expression for OD size.
Please click "Accept Solution" if what I wrote solved your issue!
Message 4 of 13
iros102
in reply to: Don.Cyr
I watched the video. It's much easier with a vice. But I will adopt a few ideas. I think I could create all of my soft jaws as configurations. I don't like the joints feature in Fusion, it's much more logical in Solid Edge.
Message 5 of 13
programming2C78B
Join the center of the chuck face to the center back of your part, then just a Z offset to position it "on" the jaw step of your choice. If solid edge is like solidworks, you're supposed to constain every axis one at a time. In fusion, you constrain everything in one joint and THEN allow it movement, if required (a bolt used to need 2 joints in SW to be fixed, in F360 it only takes one)
Message 6 of 13
a.laasW8M6T
In the latest update there is now an "Insert component" feature which allows you to more easily select a work holding template and insert it into your file, rather than navigating to the location in the data panel.
This speeds up the workflow quite a bit
Message 7 of 13
iros102
in reply to: a.laasW8M6T
Oh nice, i will try it.
I would like to try to create all my clamping jaws as a configuration so that I can change more quickly.
Message 8 of 13
a.laasW8M6T
I Finally got around just now to setting up all my Lang Vices in a configurated Template
Here's a vid of how it works:
Power Data Addin:
https://github.com/schneik80/IMA-PowerData
Message 9 of 13
iros102
I don't know why, but I don't have these functions like you showed in the video and screenshot.
Message 10 of 13
a.laasW8M6T
Hi, What version of Fusion are you on?
It seems like you may not have the latest version, you should be on 2.0.19215
Message 11 of 13
iros102
I installed the insider version and now i have all these funktion.
Can you pls share your projekt with jaws configurations.
Message 12 of 13
a.laasW8M6T
Interesting, You shouldn't have needed to install insider to get access to these features, they are in the production release.
Here is the attached vice config
Message 13 of 13
iros102
My Fusion 360 wouldn't update. Maybe the new version wasn't released for Germany yet.
Thank you for your help.
