Hi everyone, please forgive me if this is a really amateur question but I can’t seem to find the answer anywhere. I have been advised to use Sandvik tools when programming but I cannot seem to import the STP files from their website into the tool library in Fusion 360. Please help!
thank you
@nocturnalwelding wrote:
I just want Haas tools.
Milling or Lathe tools?
If "milling", what is not in the library currently?
Lathe tool import (solids) is on the backburner for a bit, sadly.
Only Endmills are imported for milling tools from Haas tooling. I too am trying to find a way to import all other cutting tools (non lathe) tooling from them.
Hello, I am following up on this. I have attached the lathe tool that is giving me trouble. Any help would be great!
