Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
How to use the side of an endmill to cut sideways though an oval hole/slot
3 REPLIES 3
derek_secord12
391 Views, 3 Replies
I have tried to find something online but I couldn't find anything more specific about how to have an endmill plunge/step down into a part and cut across/sideways though the oval hole/slot and have it repeat the prosses until it reaches the bottom. i thought it was an adaptive cycle or a drill cycle but I didn't have any luck with that.
3 REPLIES 3
didn't mean to make a reply.
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply.
Are you looking to ramp down the entire profile, or just cut on centerline back and forth until reaching final depth?
Seth Madore
CNC_Lee
in reply to: derek_secord12
@derek_secord12
You can use a 2D Contour toolpath with the Ramp box checked and angle defined in the Linking Tab to ramp down along the profile or use the Slot toolpath to machine depth passes on the centerline of the slot geometry.
If my post answers your question, please use Accept as Solution.
CNC Lee
Autodesk CAM Post Processor Expert
https://linktr.ee/cnclee
