@Anonymous
hmmm, when you say that you exported the stock to STL, do you mean like this:
Op2 setup used the rest material from setup 1. Then you exported the resulting stock after op2 setup (to STL), and opened that STL file to see if it was good?
If that is what you mean, then yeah... this is not what I meant... hehe
So, if I take your example to illustrate back what I meant:
op1 setup as cylinder, everything ok with that, even export to NCSimul.
Op2 setup, choose to use the rest material option from op1 setup. Works perfectly inside Fusion. But, when exporting that to NCSimul, that exports the op1 stock again, not the result after op1, but the original cylinder, and that is bad...
I believe this is then result of what you said before, that it doesn't show the correct size preview in the op2 setup. When exporting to NCSimul, I need the stock for op2 setup, which is the result after machining op1.
Yes, exporting to STL after simulation does the export correctly, but this is not what I need.
I hope it makes sense... I think we are after the same thing, that the stock in op2 is loaded internally only, so cannot show the preview correctly, and also cannot show the size preview.
