Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
how to thickness plane your stock
5 REPLIES 5
jb102167
303 Views, 5 Replies
jb102167
After facing my stock, I need to turn it over and face (or thickness plane) the other side of the material to the exact thickness of my model. How is this done?
5 REPLIES 5
seth.madore
in reply to: jb102167
seth.madore
Create a second setup and define your heights accordingly?
Seth Madore
Seth Madore
jb102167
in reply to: seth.madore
jb102167
Would I do a tool touch at the spoil board (vacuum jig). If so, how would I alter my heights tabs to get the thickness I am after
seth.madore
seth.madore
It would be easier to explain and show if you could share an example file.
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Seth Madore
seth.madore
seth.madore
Are you setting your WCS zero as well as your tool offsets on the spoil board or the top of the finished part or top of stock?
Seth Madore
Seth Madore
leo.castellon
leo.castellon
One way is to program your part with the tool always being set to the top of your spoil board. Doing it this way, then you only have to set the tool once. See attached.
LeoC
LeoC
