How to set safe retracts w new post process UI
I'd like to set my default Safe Retracts to "Clearance Height" instead of "G53". I knew how to do that with the old post process UI, but can't seem to find it anywhere with the new one. I can change it each time I post process something but that's a bit tedious. Anyone know how?
KrupalVala
Hi @Anonymous ,
Once you select a post in the NC program and change/set the post-properties then the changes remain the same in all cases.
Krupal Vala
Senior Technology Consultant - Post Processor & Machine Simulation
You were right, editing the file did the trick. Thanks!
