Message 1 of 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a disk with a cutout. I want to face the surface of the disk, but restrict the machining area so the bit does not pass over the cutout. With other toolpaths, I can select the machining boundary using a Sketch selection, but that doesn't seem to work for the Face toolpath.
Under Face: Stock Contours, the pop-up info says I can select any size or shape area to Face. But I must be missing the trick.
Any suggestions? Thanks!
