How to restrict machining area for 2D Face operation?
sjj530
Message 1 of 11
sjj530
I have a disk with a cutout.  I want to face the surface of the disk, but restrict the machining area so the bit does not pass over the cutout.  With other toolpaths, I can select the machining boundary using a Sketch selection, but that doesn't seem to work for the Face toolpath.
Under Face: Stock Contours, the pop-up info says I can select any size or shape area to Face.   But I must be missing the trick.
Any suggestions?  Thanks!
Replies (10)
Message 2 of 11
Joshua.Aigen
Hi @sjj530, Would the parallel toolpath work, I bet with a bit of work this could be even better.Forum.JPG
Edit: Using Avoid surfaces with 0.1mm and selecting the three surfaces inside the cutout I was able to avoid the area completely.
Joshua Aigen
Workshop Supervisor
Message 3 of 11
sjj530
Thanks for the response.   That's a good idea.   The paralell toolpath does avoid that area while cutting, but the toolpath still passes over the cutout, which I want to avoid.
In the actual design, there is a block taller than the disk occupying the cutout space.   Originally I defined the stock to include that block, but the Face operation still passed though the space of the block.  That stumped me.  I tried removing the block and replacing it with a cutout just to simplify the problem while I looked for a solution.
Message 4 of 11
Joshua.Aigen
Yes, that's where Avoid surface comes in, it's in the geometry tab in the Parallel toolpath. Or you could put the block back in I think that would work with parallel.
Joshua Aigen
Workshop Supervisor
Message 5 of 11
Joshua.Aigen
Adding in the block I just had to turn on model and select the 2 bodies.Forum.JPG
Joshua Aigen
Workshop Supervisor
Message 6 of 11
sjj530
Thanks for the response!   Hmm.  I wonder what I'm doing wrong?   It doesn't seem to work for me.
Any chance you could upload your modified  .fsd file so I could see  how it works in practice?     Thanks!
Message 7 of 11
engineguy
@sjj530
Have you tried using a simple 2D Contour and using it`s sideways "Roughing Passes" to step across the plate, see images below and attached file, might not be what you want but it seems to be fine here 🙂 🙂
First image is using the Disc as "Stock Contour", second image is using your square "Relative Stock" as the "Stock Contour", the toolpath starts and finishes off the Stock which is "best practice" IMHO, I just had to add an extra pass for the bigger stock to face it off completely 🙂 🙂 🙂
Message 8 of 11
Joshua.Aigen
Here is the file I created, just make sure to check your step-over, feeds & speeds etc.
Joshua Aigen
Workshop Supervisor
Message 9 of 11
engineguy
@Joshua.Aigen
Looked at your Parallel file and it doesn`t appear to cover all the area needed to face the disc off, see image below, the Red rectangles show where the tool doesn`t cut.
Message 10 of 11
sjj530
Thanks, engineguy! Yes, I think your approach will work. I just started out trying to make the 2D Face toolpath work, since this really is a facing operation. And then I just tumbled down the rabbit hole in trying to find a solution. I hadn't even considered other toolpaths. Thanks!
Message 11 of 11
sjj530
Thanks, Joshua.   The example file helped a lot.  I just ran the parallel toolpath and it avoided the block area as desired.   Thanks for the support!
