I have a Machine Configuration in my Machine Library. I am about to buy a second, differnet CNC machine and I want to create a new configuration for it. I can see/edit my machine #1 configuration in "Machine Library / User Library" but I just realized it never shows up when I begin a new set up for an operation with Machine 1 ? Where did it go? I guess I did not notice before it was not there?
How do you make it so Set Up shows your CNC machines? Sorry if this is a really basic question but I am stumped.
Jgaertner
Solved by seth.madore. Go to Solution.
They "should" be in your Cloud library. Are you not seeing those?
Hello Seth, I was expecting to see the different CNC machines I could choose from in the set up box like in the Fusion 360 tutorial? Red arrow pointing to the area where the machines are supposed to be, I thought?
Here is a screen shot from my computer. I do have my #1 machine in the cloud folder.
Thanks. Jgaertner
Samples doesn't give you anything?
Yes, I have all those choices. But I was under the impression from the Fusion Tutorial that the 2 machines I created in my Machine Library wood show when I did a new set up? Machine #1 and Machine #2 for lack of a more creative way of addressing them. So one is a CNC mill and the other is a CNC router. No choice of machines appear when I do a new "Setup" in Fusion? Maybe I miss understood the tutorial?
Oh oh oh oh! I see what your issue is now, I didn't see it clearly from your photo. You need to go into Preview and turn on Machine Configs:
Machine Configurations has been moved out of Preview and should be available in the product already.
Yes i can see that botton but i want this simple machine milling 3 axis but i dont how to visualize it. May be first i need to configurate the axis, which machine i have to select to simulate like you see in the first capture, I don´t know my friend. Do you have a video tutorial of that?
