Hi, I have a component, with a hole with 25mm diameter, but I want to make a hole with 12x16mm to insert a alloy plug .
In powermill I recognise the size and change hole size manually to 12.
In fusion, the only way I see, it seems by doing some math and increase radial stock, or design a hole with 12mm dia
Is there a easier way?
Solved by CRANDALLPRECISION. Go to Solution.
Solved by Linus_Follinger. Go to Solution.
Hi @nubrandao , head over to the "design" workspace and edit the model.
Thats whats i would do.
But yes you could use "stock to leave" and "Height" in the "manufacturer" workspace, to get a 12x16 bore.
Maybe is better to add stock to leave, I have to do the math
The model usually has a bigger diameter, but the final diameter will be machined in another machine, all I have to do is a smaller hole, so they can center in a different machine.
In the drill menu under cycle type select bore milling and use the hole for location then enter the diameter you want.
That's it 🙂
