Fusion Manufacture
How to access Tool Library "Shaft" Tab.
1 REPLY 1
monozukuri.daisuki.higucchan
281 Views, 1 Reply
Thanks for your support.
What is the best way to access the shaft segment of the tool library from the post processor?
In the Dump file there is an entry for the shaft upper diameter/lower diameter and these values seem to match the Fusion parameters, but the shaft height parameter values do not seem to match.
Any hints as to what these parameters mean would be helpful.Dump file.pngShaft segments.png
Labels (1)
1 REPLY 1
I checked with Dumper and found a variable to access the parameter!
Thanks.
