I'm trying to drill 3 holes in my stock setup using Hole Recognition. The simulation shows all three holes being drilled but the program only exports gcode for the first hole and not the other two.
Solved by Richard.stubley. Go to Solution.
Hi looking at that Gcode I would say it was drilling all 3 holes.
Have you run it on the machine?
Looking at it through https://ncviewer.com/ shows all 3 holes being spotfaced and drilled.
Yes, I tried it on the machine and it drilled all 3 holes. I'm not sure what was going on before but I did modify some things before posting the gcode to the forum. Thanks for your response!
