Hello All,
Attached is a 4th axis rotary manufacturing setup that I haven't figured out how to get what I want from it. I am utilizing a form tool that has 2 angles and a radius on it. I believe the issue begins when I am selecting the tool orientation position for the Z axis in the multi-Axis section for the 2D contour. Technically the geometry I am utilizing would not be perpendicular to Z due to the angle however, I haven't come up with a solution of choosing other geometry. I also believe I have issues with the radius on the form mill with choosing the correct compensation point. I have done workarounds in the past with just eliminating the angled undercut and deleting the radius then 2D contouring a workaround that isn't correctly modeled to the part but, I'm hoping there's a different solution rather than this to stop from continuing the workaround. You're help is much appreciated in advance!
