Help with Z Axis Orientation When Using Form Mill While Utilizing 4th Axis Rotary
xkutusa
xkutusa
Hello All,
Attached is a 4th axis rotary manufacturing setup that I haven't figured out how to get what I want from it. I am utilizing a form tool that has 2 angles and a radius on it. I believe the issue begins when I am selecting the tool orientation position for the Z axis in the multi-Axis section for the 2D contour. Technically the geometry I am utilizing would not be perpendicular to Z due to the angle however, I haven't come up with a solution of choosing other geometry. I also believe I have issues with the radius on the form mill with choosing the correct compensation point. I have done workarounds in the past with just eliminating the angled undercut and deleting the radius then 2D contouring a workaround that isn't correctly modeled to the part but, I'm hoping there's a different solution rather than this to stop from continuing the workaround. You're help is much appreciated in advance!
da_fish
Hi, In regards to your first question about tool angle. You can create a sketch in the Design environment and then use that for your tool orientation. For Example:
And in regards to your second question, You are selecting the correct line as the contour and the form tool compensation point is correct. The problem is that your bottom height setting was wrong. Make sure it is set to "Selected Contours" as shown. This should fix that issue.
I hope that works for you! If not, please let me know.
xkutusa
Thank you greatly for your help! I'll attach the updated solution for anyone else that might have a similar question. Thank you again!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
