Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Help with Toolpath
3 REPLIES 3
190 Views, 3 Replies
Help with Toolpath
I can’t create a toolpath that will mill the fillets on the curved areas of the treble clef. The first toolpath listed is a 2D contour to cut out the shape. The next 3 toolpaths are my attempts to mill away the material above the treble clef. I tried Scallop, 3D Contour, and Parallel. They only remove material along the straight portion of the treble clef.
Any help is appreciated. Thanks.
3 REPLIES 3
Some additional details: The sloped portions of the model were created by splitting the bodies using a plane. It's these areas where the toolpaths fail. I originally thought that the unused portion of the split bodies was causing the problem. I did not delete them initially, but moved them to a different component. Since the toolpaths all act like the surface is flat and flush with the top of the model, I assumed that somehow they got included in the Manufacture selection. I then deleted those bodies to eliminate this possibility, but to no avail.
daniel_lyall
If you do a boundary fill of the model so there is only 1 body it will help a lot, the model is very dirty and some of the surfaces don't meet up very well, this is what the problem is.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
in reply to: daniel_lyall
Thanks for the help. I struggled to make the boundary fill work, but in playing with it I saw that I still had the bodies I split to make the sloped surface. By making sure they were not selected in Manufacture, all toolpaths recognized the surface. As a hobbyist, I definitely struggle to make Fusion do what I want. Thanks again.
Technology Administrators
