So i've been messing around in blender for a couple hours and came up with a rough "fleur de lis" design. I imported it, scaled it properly and meshed to brep. I created a backing for it so that I can clear it from .5" stock.
In 3d adaptive clearing i've tried every combination of selections for the model i can think of. first just the model, then model and face, etc. every time it comes up with "empty toolpath" I've done 3d clearings before but this one is really stumping me. thanks for any help. file is attached
-Russ
Solved by Matthew-R. Go to Solution.
@Anonymous Thanks for posting your question to the forum. I opened up your file and it looks like you just had to select the appropriate bodies in the setup. Hope this helps!
It's been a trip learning how to use blender and my mind has been going a mile a minute. easy to overlook something simple like that. thank you very much!
