I have a machine as shown in the image below:
Where follows the Axis pattern Normally.
Is it possible to invert the Y and Z axes?
I want to position the assist pieces.
I'm using the NCT Generico Post Processor.
Is it possible to change the axes in Fusion or Post Processor?
Do I need to change something?
Can someone help me ?
Invert the axis on your simulation, or the code that is being output?
Is Z still not the axis in line with the rotational axis of your spindle?
-I positioned the Block in relation to the machine.
-I did a Drilling Cycle with the guided Tool
-An error occurs when generating the NC Program
Below is the Post Processor I'm using.
Would it be possible to invert the Z and Y Axes in it?
