Hello
I'm new in editing postprocessor and I have a question.
I am trying to edit postprocessor for machine with rotary cAxe and 2 position spindlehead (aligned with Z axe or withY axe)
I managed to enable rotary axe, but i have a problem with head tilting
Head is tilted with code M53 and M54 (it only has 2 positions). I looked for an answer which postprocessor uses these two codes but without success.
Is there's anyone who uses same type of machine with simmilar propperties and is willing to help me? Is there maybe already prepared postprocessor for machine like this?
Thank you all for your time and answers!
Žan
I would say you will need a custom post processor, but depending on how you need to operate the machine you could get away with more simple mods.
when you rotate the head to the Y do you program with tool axis set to Y or do you use the 3d basic rotation of A-90 so the tool axis stays as "Z"
Hello
Thank you for your answer.
I tried to orientate the tool with tool orintation (where you chose z and x plane in toolpath settings) but after postprocess, tool orientation was still aligned with Z (not with y as it should be)
As you said, I can use 2 different post processors and mannualy type in M53 and M54 codes, but problem is, I cant even get post processor to rotate tool axe correctly (so the tool is no longer on Z but Y axe)
Thank you for all your help
Have a nice day,
Žan
