When I add probing to my final machine program to inspect the part. It post fine but I have no Idea what the G9810 codes mean where is the data that tells me what the probe measured. The probe worked fine but where do I find the data on the has machine or do I need some kind of setting installed on the Haas?
Solved by Steinwerks. Go to Solution.
Solved by LibertyMachine. Go to Solution.
The value is stored in a variable on the machine. This is not a Fusion post matter, but more that of becoming familiar with the probing function. On my fanuc machines, I believe the value is stored in #140-#150 range
As @LibertyMachine noted, this is about knowing how your machine uses the probing cycles.
Here's the manual: https://diy.haascnc.com/sites/default/files/Locked/2/Renishaw_Programming_Manual_H_2000_6222_0A_B.PD...
It can do far more than what is in HSM right now, by the way, so have fun with it!
