Solved by MattWynn. Go to Solution.
Attached is an example of what I would like to see. It would be cool if we could set the % power and set a "rpm range" (power setting) and have the software set the appropriate spindle on with rpm to set the power.
I'm pretty sure we made a grbl post that worked with the waterjet/laser/plasma operation that would do the right thing with power (S word was it?). Don't try to use router operation when the laser operatoin is what you want.
Try the postprocessor from @skidsolo in this discussion: http://forums.autodesk.com/t5/computer-aided-machining-cam/newbie-needs-help-with-plasma-waterjet-po... Also just search this forum for "grbl laser" for some other discussions of interest.
I was using the Laser toolpath. I did find the post you mentioned and was able to get it to post but it is not posting a "S" to set the power and I tried posting 2 seperate cuts and it doesnt seem to turn the power off and back on. Seems like when it retracts it should set power to 0 then rapid then start cutting again. I didnt see any settings to set the power for the laser.
I think the cutting mode on the laser operation would set different power settings.
Here are 3 seperate posts with the "laser mode" set to 3 different quality settings. nothing is changing. and there is no "S" and a number to set the power. Maybe there is something I am missing but it doesnt seem to be working.
perhaps I was thinking of the smoothie with the S word.
Take a look at the smoothie post for how to get the power settings for the waterjet/laser/plasma operation, http://cam.autodesk.com/posts/?p=smoothie .
that doesnt seem to help much with GRBL controlled machines. is the development team still working out the bugs with the laser/waterjet/plasma CAM programming? it seems pretty standard in the several laser programming programs to set the power as I described it earlier with a pwm input. I hope they are still working on it because as it is, fusion is useless for laser programming. I love fusion and hope they get it worked out.
thanks,
Tim
I'm glad you love Fusion. Many people are having success with laser programming using the WLPC operation.
The problem here is the postprocessor, not "bugs with the laser/waterjet/plasma CAM programming" (which there may be, WLPC is still in preview).
Take a look at http://cam.autodesk.com/posts/ and filter on the waterjet / laser / plasma type. There are several good posts that show how to get 6 different power levels for WLPC. Note that the generic grbl post does not yet have support for laser - which is why I pointed you to the other one.
did you see this section in the smoothie post?
/** Returns the power for the given spindle speed. */
function
getPower() {
switch
(currentSection.jetMode) {
case
JET_MODE_THROUGH:
return
properties.laserPower;
case
JET_MODE_ETCHING:
return
properties.laserEtchPower;
case
JET_MODE_VAPORIZE:
default
error(localize(
"Laser cutting mode is not supported."
return
0;
for through cutting ou can use this code to get the quality values that can be mapped to 4 different power settings (from the OMAX post):
switch
(currentSection.quality) {
case
1: // high quality
qualFeed = 5;
break
case
2: // medium
qualFeed = 4;
break
case
3: // low
qualFeed = 2;
break
default
: // auto
qualFeed = 3;
Thanks Matt,
I will look into it. maybe I can edit the GRBL post to output what I need for my setup. Thank you for all the help 🙂
Tim
One other feature that might be nice is a multipass with step down control. for those of us with whimpy 2-3 watt lasers we need to take multiple passes to cut through thicker materials.
No plans to do this for WLPC. I can suggest copying an operation, and setting different height.
( I'm used to 1000 - 8000 watt lasers... )
@Anonymous What did you make? Send Pictures!
I have just done a few tests but the smoothie post is working reasonably well. The smoothie post doesn't end the program automatically with grbl so it needs a little bit of work.
Is there true engraving ability though? I see there is a way to set multiple power levels for a single tool path. However, an engraving toolpath will change the laser intensity based on depth, right? It's essentially a pocket operation but instead of changing the Z axis for depth the laser power is increased. From everything I've seen here, only one hardcoded power level (through, etching, or vaporize) that can be used per tool path. Anyway to have it dynamically change throughout?
Fusion doesn't have a way to do etching. I was going to try and do a pocket tool path but haven't had much success or time to work out the issues. I have been using laser etch fron jtech photonics for etching. it works really nice! I am also using picsender as the gcode sender program for my GRBL based CNC machine. https://jtechphotonics.com/?product=laser-etch-bw-image-engraving-sw-license
All settings are constant within each WLPC tool path.
You might be able to hack something together mapping z heights to power.
