- Mute
- Permalink
- Report
Hello everybody!
Im new to CNC and Fusion360. I have build a simple cnc machine called Most Printed CNC (MPCNC) that uses the same structure as Reprap 3d printers.
I have made a model on Blender, and exported as .OBJ. I did all the process to cut a 2D contour, exported the gcode, and tested it with a pencil.
The problem is: It makes strange movement at the corners. At the image bellow you can see that the pathway at the left (made using a pencil) is not 90 degrees as it should be ( at the right), and i can see the X motors moving while they should be still.
i ran the gcode on CAMotics ah it generated a perfect pathway:
To test the machine I built a similar structure on fusion and the pathway this time was right as image bellow ( the motor was still this time):
Does someone has any idea why is it happening?
Im asking it because i use blender as my main modeling software and i would like to use fusion360 to export the gcode to my CNC machine.
thanks
