G-Code Highlighter for Brackets
martha.deans
Autodesk Autodesk
Message 1 of 16
martha.deans
I was feeling inspired this week, and took a stab at writing an extension to highlight g-code files in Brackets like below:
Let me know what you guys think!
(here's a video that's like 30 seconds and shows how to load the extension 🙂 )
Marti Deans
Product Manager, Fusion 360 Manufacturing
Replies (15)
Message 2 of 16
daniel_lyall
yes that is better do it own it name it
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 3 of 16
Is it rude of me to say I did it first? http://forums.autodesk.com/t5/computer-aided-machining-cam/the-brackets-editor-syntax-highlighting/t...  😛
Just kidding! Good to bring this back up.  Why isn't this distributed with Fusion?
Dave
Message 4 of 16
LibertyMachine
That looks really neat! Question though: Is Brackets ever affected by Fusion updates, or does it take something significant to have any impact on Brackets?
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Message 5 of 16
al.whatmough
@martha.deans
5 Kudos for your very first post on the Forum.  You set the bar high you know!
AL Whatmough
Director Product Management - Manufacturing
Note, I love to engage on the forums. However, I spend a lot of time in meetings trying to help clear the path for our amazing team of Developers working on Manufacturing at Autodesk. So, if I don't respond immediately, it's not that I don't care.
Message 6 of 16
wellisonS6RTG
Hi Martha,
I've downloaded and installed the Simple G-Code Syntax Highlighter for Brackets.  It works great for newly posted programs but I notice that for files downloaded from my machines the hightlighting doesn't work.  Is there a known reason for this?  Thanks.
-William
Message 7 of 16
martha.deans
Hey William,
All the file extensions for which files Brackets identifies as NC code are hardcoded into the extension, so if the file you're downloading from the machine isn't included then it won't have the colors applied. You should be able to tell Brackets that it's "G-Code" with the list in the bottom corner and I think even set the default type for that extension.
Hope that helps!
Marti Deans
Message 8 of 16
wellisonS6RTG
Thanks Martha!  That was very helpful!
-William
Message 9 of 16
Stuart-H
Dare I say visual code with the code hilighter installed is a bit nicer than brackets
hilights jarvasctipt and gcode very well
win and Mac are available
I keep getting errors about brackets in Mac OS because it’s looks like it’s 32bit
Mac Studio M1Max and MacBook Pro M1
Message 10 of 16
daniel_lyall
@Stuart-H  VSC has a post-editing addon for fusion and HSM post-processors as well.
Daniel Lyall
The Big Boss
Mach3 User
Message 11 of 16
jeff.pek
FYI, we are planning to move away from Brackets as the default NC code (etc.) editor for Fusion. This is due to new requirements for MacOS, which Brackets does not meet.
You are, of course, free to continue to use Brackets as a "custom editor" via the preferences setting.
  Jeff
Message 12 of 16
itstimetolivenow
Good afternoon!
Its interesting, but this file "brackets-gcode-syntax-highlighter.zip" not found. Please download again.
Message 13 of 16
martha.deans
If you're looking for the .zip file itself, you can download the extension at the top directly under my original post. The video will take you through the steps to install it into Brackets!
-Marti
Marti Deans
Message 14 of 16
itstimetolivenow
Thank you.
I successfully downloaded the extension file. But now another problem - video instruction is not available.
Message 15 of 16
martha.deans
That's what I get for linking to my personal Dropbox 🙂
Here's the QUICK TIP on YouTube that walks through the same info: https://youtu.be/onbWqOMkaFI
Marti Deans
Message 16 of 16
itstimetolivenow
Thank you very much. Everything works perfectly!
