Hello, I have a cnc mill (router) and have got a 8w Laser head which Id like to use to laser engrave some anodize aluminum.
This is the head Ive got:
https://www.ebay.com.au/itm/30W-Laser-Module-Laser-Head-450nm-Blue-Lase-for-Laser-Engraving-Machine-...
I Run my machine with Mach4 and ESS smoothstepper.
Can anyone help with me how to wire up the laser head and to make a post processor so Fusion Trace toolpaths will engrave?
Solved by daniel_lyall. Go to Solution.
Solved by engineguy. Go to Solution.
Try here for more infromation and a downloadable Post Processor for Mach3 that may work for you 🙂
As for wiring it up again the folks at the link above should be able to help you 🙂
Stay Safe
Regards
Rob
https://warp9td.com/index.php/faq/faq-mach4#LaserSetup
