Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Fusion hangs when using boring bars
9 REPLIES 9
Message 1 of 10
Luke.Hicks430
424 Views, 9 Replies
Luke.Hicks430
Something that has cropped up for me repeatedly over the last week: Fusion hangs when trying to implement an internal boring tool in a turning operation. I can't even submit a crash report. I have restarted Fusion every time. I have restarted my PC a couple times. Everything is fine, even when defining the boring tool, and define the operation, but when I click 'OK' to generate the toolpath, it hangs. You can see in the screen capture, in the lower right corner, is says 'Updating stock boundaries (99.9%) ...'
Has anyone else had this problem?
Have you found a solution that's better than re-installing Fusion?
Thank you in advance!
9 REPLIES 9
Message 2 of 10
akash.kamoolkar
@Luke.Hicks430 Could you attach a sample file where this is happening?
Akash Kamoolkar
Akash Kamoolkar
Software Development Manager
Akash Kamoolkar
Akash Kamoolkar
Message 3 of 10
Luke.Hicks430
Unfortunately, due to NDAs, I can't use the exact file that is crashing.
When I tried duplicating the problem in another file, it wouldn't do it.
Oddly, when I rebuilt the original part completely, the problem persisted, and, unfortunately, the NDA still applies.
Finally I took working file and re-dimensioned the solid to match the customer's part, there was no crash. So I have no idea what caused the problem and I have no idea as to what fixed the problem.
So.... Thanks?
So.... Thanks?
Message 4 of 10
mhoog
in reply to: akash.kamoolkar
mhoog
I have the same problem; boring bar crashes fusion 360 and its stuck at 0.0% tool path generation but at 99.9% Updating stock boundaries. Anyone have a fix? I cant generate gcode for the parts.
I can privatly share source file if that would help; best way?
Message 5 of 10
akash.kamoolkar
in reply to: mhoog
akash.kamoolkar
@mhoog @Luke.Hicks430 By any chance do either of you have in-process stock turned on? If yes then that is a known issue one of our teams is working to fix right now. In which case a temporary workaround would be to turn it off.
Akash Kamoolkar
Akash Kamoolkar
Akash Kamoolkar
Akash Kamoolkar
Message 6 of 10
mhoog
mhoog
I do not; i only have transparent stock enabled.
I will PM you a Public Link to the file that has the issue; would this help?
I have copied the tool paths from a older working file and it generates the tool path fine in that old version but on this new file it keeps crashing. Its the last 2 operations that cause the issue.
Message 7 of 10
akash.kamoolkar
in reply to: mhoog
akash.kamoolkar
@mhoog Yes, please send me the link. I will take a look. The OP does seem to have in process stock turned on in the pic now that I look at it so your problem might be a separate one.
Akash Kamoolkar
Akash Kamoolkar
Akash Kamoolkar
Akash Kamoolkar
Message 8 of 10
akash.kamoolkar
in reply to: mhoog
akash.kamoolkar
@mhoog I can't replicate the crash. I'm using the latest Fusion update 2.0.9313. I was able to generate the roughing op correctly. To generate the finishing op i had to move the outer radius to above the inner radius.
Akash Kamoolkar
Akash Kamoolkar
Akash Kamoolkar
Akash Kamoolkar
Message 9 of 10
mhoog
mhoog
I am using that same version of fusion 360 on windows 10.
I am using the directions on the link below to turn off the "in process stock" but there is no check mark next to it so i think its off. As soon as I suppresses the op and try to generate the tool path it crashes. Is there a different method to force stock off?
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
Message 10 of 10
akash.kamoolkar
in reply to: mhoog
akash.kamoolkar
@mhoog your in-process stock is turned off and I still can't replicate your issue. Maybe try rebooting your computer and then regenerating them. Sometimes that works in stopping chronic crashes.
Akash Kamoolkar
Akash Kamoolkar
Akash Kamoolkar
Akash Kamoolkar
