Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Fusion crash when wrap tool path simulation
4 REPLIES 4
qamar_razaSY3K
170 Views, 4 Replies
When I try to simulation a wrap tool path suddenly fusion get crash.
4 REPLIES 4
Hi
Can you share the file that is causing the problem?
Goto File>Export>Save as .f3d/.f3z
Are you getting a Crash error report when this happens?
Find Attached file.
Problem with chamfer tool.
Wrap toolpath always fusion crash when chamfer tool.
It looks like this is being caused by your tool definition. You have it defined with a zero diameter flat and this is causing the issue. In reality, your tool most likely does in fact have a flat, likely in the .25mm range.
Setting a non-zero value will allow simulation to proceed as expected.
-EDIT-
I've opened CAM-55967 to investigate the issue
Seth Madore
Thank you for solution
Technology Administrators
