Fusion 360 purposed UI changes
phil
phil
What do you think about the purposed UI changes?
See attached PDF.
Replies (8)
scottmoyse
Yeah I totally agree with all of that.
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
phil
Thanks for you support.
jbisme
Allow editing of all machining parameters in the Template Library UI. Fusion 360 UI for templates is totally dependent on the small, tabbed dialog user interface. Not good enough.
jbisme
Move CAM saved views out of the tree and add a button to the bottom of the graphics area with all the other buttons.
jbisme
Add a side panel like Autodesk, Delcam, Featurecam for an Operation List:
OP List
phil
The UI I was talking about is in the PDF I attached.
jbisme
Saw it. Mine are added suggestions for UI improvement.
phil
Got ya.
