Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Fusion 360 CAM - Thread milling - Unwanted tapered tool path
1 REPLY 1
297 Views, 1 Reply
Hi all.
Had an issue today that seems like a bug. Am keen to know if anybody has experienced or reported the same.
I did a simple 2D thread mill tool path for a 1/2"x20 UNF hole and during simulation discovered that the tool path was tapered (ie: cutting a tapered thread likle say an NPT thread where the tool wasn't touching the hole walls at the bottom of the hole but cutting full form closer to the top).
I thought I would find the answer in the Passes or linking tabs but there really is no option for selecting a tapered thread tool path or any way of modifying the helix angle as you would during Adaptive or pocket clearing etc.
After much head scratching and a process of elimination I found that by selecting "In computer" as my cutter comp option the tool path went back to a parallel tool path. Sure enough, changing the option back to "In controller" generated a tapered thread tool path.
This doesn't make sense to me. Is this a bug?
I have successfully thread milled with the "in control" option selected previously without this issue.
1 REPLY 1
LibertyMachine
Certainly something we want to look into. Can you share your file?
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
