Hi to all.
Could someone explain to me what have had happened here.
In the CAM of Fusion 360 I have got a program. When I want to simulate the milling operations, there is a glitch - simulation doesn't work (not all of the operations, just two of 2D contures of 5 operations). It was working before, but sudenly it has stopped to work. There is huge time of machining in estimated time and ,,nan mm" machining distance. G-code seems to be fine, and setup sheet is also showing real time and distance. I donť know what happend. See printscreen enclosed (one is simulation and the other one is setup sheet).
Thank you for your answers.
Jan
I will need to take a look at your part to see what’s going on. Can you export it as an .f3d and post it here?
I am sorry for the late reply. I didn't notice the answer.
I solved the problem. It was a glitch (unfortunately I don't have the glitchy file anymore). I just deleted the glitchy operation and created a new one and it works fine. I guess it could be caused by don't exiting Fusion360 befor hibernating my MacBook or so
Thank you fro your answer. Have a nice day.
Jan
