funky toolpath in 4th axis (What is wrong with this?)
CuttingEdgeManufacturing
Hello all, im working on some similar parts to what i have done before, basically a variable pitch thread for a customer.. im able to draw and program it wayyy faster than i used to thanks to all the help i get on the forums here. and today i thought i'd take it to the next step and actually just chamfer the edges(edge break) so its less deburring out of the machine. well for whatever reason the trace command on 4th axis does not like to draw in the lines.
this is what i got, not to sure why at all it would do this.Screenshot (22).png
seth.madore
Hmm. 2D Trace doesn't support Wrap toolpaths, so I'm curious what you are actually getting in this regard. You "should" be able to use 2D Contour and turn on "Chamfer" functionality. Could you share your part?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
i used "create derived operation". and selected trace. it wrapped it, just not properly.. parts are already done now.. but still curious what i can do next time. i never think to use the 2d contour and use the chamfer tick box.
also, i switched it to a left hand thread now, so the trace path is still for right hand. thats why it is completely wrong now.. didnt notice that till after i exported it.
seth.madore
That actually sounds like a bug... Certainly not likely intended functionality. I'm gonna have to give that a look 🙂
Seth Madore
good maybe i helped out this time lol instead of needing the help
