Hello, there is a "folder" menu in the operations menu, what is the practical use? Is it because of the organization of the program, or does it have some other use. I'm still new to Fusion and haven't found much info on it in the help.
Solved by programming2C78B. Go to Solution.
you can organize toolpaths by strategy or positions on the part, as well as Override the WCS number.
