Flat Toolpath- radial negative stock to leave doesn't work
matthewrjacobs
matthewrjacobs
As the title says.   I can't get radial negative stock to leave to work with the Flat TP. Axial seem to work OK .  Seems like a bug, unless there is some other setting that prevents this.  bleow is a mock-up
a.laasW8M6T
Hi
It works fine for me.
Because I cannot see all your toolpath settings, I'm going to take a guess that you have a boundary selected and that is preventing the toolpath from going outside the boundary
You would need to give it an additional offset to allow the negative stock to leave to work
Andrew Laas
Senior Machinist, Scott Automation
matthewrjacobs
Huh, I guess I've never used neg stock to leave in a 3d toolpath.   I was under the impression that neg stock to leave would override that,  but I guess the tool boundary trumps that.   Thanks @a.laasW8M6T for  the help
