Fusion Manufacture
Finhishing
3 REPLIES 3
rishivadher
1008 Views, 3 Replies
Finhishing
Hi there
is a way on Fusion 360 to machine a 3D contour just of a face, in this case just want to machine the interior curved face on other direction I can do that with parallel, put it select all the surfaces nor just the one curved side.
I've put some images of what part I’m trying to do a finishing
Best Rishi Vadher.
3 REPLIES 3
fonsecr
in reply to: rishivadher
Set the machining boundary for the Contour operation to machine with the "tool center" going to the Silhouette. This is controlled on the Geometry tab (the 2nd one).
René Fonseca
Software Architect
rishivadher
in reply to: fonsecr
Hi fonsecr
thanks for the replay. Made a simple machining with foam just for test, and the result was this without the finishing. And now when have some time will machine it in wood, the toolpaths are like this the images below.
Best Rishi Vadher.
rishivadher
in foam is looks like this 😉
Technology Administrators
