Fusion Manufacture
Feed time in setup sheet
6 REPLIES 6
jak.walkowski
303 Views, 6 Replies
Good afternoon,
Can I include the estimated tool feed time in the setup sheet or get it by some add-in?
I need table like this:
Tool number | Operation | Est. feed time
Regards?
6 REPLIES 6
CGBenner
in reply to: jak.walkowski
@jak.walkowski
Hello and welcome.  I've moved your post here for the Fusion Manufacturing experts to see.  Good luck!
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
seth.madore
Are you asking about the Feed Distance or the Machining Time? Both of these value are output in the Excel setup sheet as well as in the HTML and (I would assume) the NC Program based setup sheet.
Seth Madore
jak.walkowski
in reply to: seth.madore
@seth.madore
I'm asking about feed time. I don't see it anywhere, but I think the fusion should know about this for cycle time estimation.
seth.madore
And how do you differentiate the terminology between Machining Time and Feed Time? How does the Feed Time better benefit you as Machining Time is awfully close (minus the rapid motions)
Seth Madore
seth.madore
The "Cycle Time" that's posted out for each toolpath does NOT include rapid moves. So, you are getting the Feed Time, in effect.
Seth Madore
jak.walkowski
That's great news :). I think cycle time includes rapid moves. In this case, Cycle Time from the tool list is what I needed. Thanks for pointing this out. I didn't check this and always think that tool list cycle time sums to estimated time ;).
