Is there a way to adjust the feed rate?
No matter where I set my feed per tooth value Fusion stays at 40 ipm.
Which Bore Cycle are you using, and what sort of tool are you using? The "Bore Mill" cycle in drilling:
is a dumbed down version of this cycle:
Although, with creative post processor editing, it does give you flexibility in the code format. However, i suspect that this is not the case in what you are trying to accomplish. Correct me if I'm wrong..
Yes that is what I am using.
I have a bunch of holes that are the same size that I am straightening up after drilling. Rather than selecting them individually with the 2d bore cycle, I thought this would give the same result and enable me to "select same dia."
Where does the 40 ipm come from?
This is a big that we have identified and fixed for the next update.
