February 2025 Post Processor and Machine Simulation What's New
andrea.amilo
Community Manager Community Manager
Message 1 of 1
andrea.amilo
Post Processor and Machine Simulation What’s New
Looking for the latest post processors and machines updates? Look no further!
We are continually working hard to bring you updates and improvements to the many open-source Post Processors and Machines we offer for free, but those updates often get lost in the shuffle of other enhancements or big feature releases. This post aims to update you on newly added or improved post processors and machines, so you can stay up to date on what you use today or look for news so you can get the most out of Fusion.
This post will get refreshed with notable updates as they’re released, and you can click each hyperlink to go to the mentioned post. As always, you can find the latest in our post processor offering on the Online Post Library where you can search by vendor, type, or name, and see any recent changes to each post processor.
MAIN CONTENTS
  1. Improved Post Processors
  2. New Machines
  3. Improved Machines
  4. New Print Settings
  5. Improved Print Settings
  6. Workholdings Library Update
  7. New Workholdings
  8. Tools and Tool Holders
  9. Post Processor Ideas
We are always working to keep post processors up to date with new technologies. This is a summary of the main improvements made to post processors already in the library.
Generic Post Processors
milling.pngFixed potentially missing Z coordinate output when using the 'Safe start all operations' option.
Mill-Turn Post Processors
Samsung Mill/Turn
Fixed the default value of the 'Transfer type' property in the Samsung mill-turn Fanuc post processor.
Waterjet/Laser/Plasma Post Processors
Avid CNC Plasma
Added the "Write Version" property to the Avid CNC Plasma post processor.
Additive Post Processors
The FFF additive post processors have been updated to ensure that the High Feedrate mapping method is set to 'Preserve rapid movement’.
Prusa
Added support for the MK4 and XL printers to the Prusa post processor.
Intermediate Post Processors
JSON Advanced
Updated JSON advanced post processor to support for imperial units.
2. New Machines
The Machine Library lets you manage your machine tools by using Machine Configurations to define your available machines and resources. These configurations can automate the settings in your Job Setup.
There are many Machine Configurations available in the standard library.
Milling Machines
You will have available configuration files for some of the leading machine manufacturers:
TT120
The easiest way to get started, is to copy an existing configuration that matches some of the characteristics of your machine.
Additive Machines
Creality Ender 3 V3 KE
Creality Ender 3 V3 SE
HP Jet Fusion 300 and 500 Series
HP Jet Fusion 5200 Series
HP Jet Fusion 5400 Series
HP Jet Fusion 5600 Series
Trumpf TruPrint 2000 S2.0
P 500
P 810
DL 321
haas_thumbnail.pngEC-500/50
MPRINT
MPRINT LAB
Photocentric LC Magna -Generic- 100 micron
Photocentric LC Opus -Generic- 100 micron
Photocentric LC Titan -Generic- 100 micron
PETG (Direct Drive)
PETG (Bowden Tube)
Micro, Midi, Midi 1200C, Midi 500C, Midi 800C, Midi D55, Midi D100, Midi+,
Midi+ D55, Midi+ D100, Midi+ D170, Midi+ 500C, Midi+ 1000C, Midi+ 500C MIDIMidi+ 800C MIDI, Midi+ 1200C MIDI, Mini, Mini 500C, Mini 800C, Mini D55, TwoTwo 200C, Two 500C, Two 800C, Two D200
P 110 - 0.06 mm, P 110 - 0.1 mm, P 110 - 0.12 mm, P 396 - 0.06 mm, P 396 - 0.1 mm, P 396 - 0.12 mm, P 500 - 0.06 mm, P 500 - 0.1 mm, P 500 - 0.12 mm, P 810 - 0.06 mm, P 810 - 0.1 mm, P 810 - 0.12 mm
PLA (Direct Drive) – High Speed
The Workholding library lets you add a workholding equipment (vise, table, tombstone, etc.) to a manufacturing model. Those can be found in the "CAM Samples" project folder that you can find in the Autodesk Fusion data panel:
We are pleased to announce that Fusion configuration capabilities are now available for files in the Workholding folder. These are used when a single component is designed with multiple arrangements.  Currently, configured designs are defined in 5th Axis, Haas, Fast Mill, Lang, Mate and SCHUNK files.  Configured designs are applied to a single model number where it may be beneficial to capture multiple ways the part could be used.
Newly configured designs are identified in the Fusion Data panel by an “orange cube with arrow” icon , rather than the simple “orange cube”:
The user can change the active configuration in the file by clicking on a drop down menu in the Browser design tree.  To control a configured vise, a jaw width control parameter has been built into the configuration tables. The control parameter will change the jaw opening to match the gripping distance entered, or the user can still join the part to the jaws graphically.
We released these to simplify the existing vises in CAM Samples, making the model numbers more visible and the menus more streamlined, while still offering the same number of design arrangements for clamping simulation.
7. New Workholdings
3 Vises
1 clamp
36 components
4 plates
The Tool Library lets you manage tools for Milling, Turning, Cutting (waterjet, laser & plasma), Touch Probes and Holders. The Tool Library lets you manage libraries of predefined tools and project documents.
ISCAR - Solid End Mills Metric, ISCAR -Solid End Mills Imperial
ISCAR's solid end mills. This library of solid carbide end mill contains the full assortment of ISCAR'S solid carbide milling solutions for application in all material types.
To make our library more varied and complete, we are always working on new post processors. Some of them still need more testing before being released in the public library. Every new Beta post processor is announced in the Idea Station, you can find all of them in the Post Processor Idea Station.
Please note that if you choose to use one of these post processors, you assume all inherent risk in using it and we ask that you proceed with caution.
That being said, we are looking forward to get your feedback!
Click here to see the previous What’s New release.
Andrea Amilo
Senior Technical Consultant
Autodesk Knowledge Network | Fusion 360 Webinars | Autodesk Make
Replies (0)
