Fusion Manufacture
Fanuc 21i on a CTX410 CAM post using G17 for udrill
21 REPLIES 21
Message 1 of 22
mjoconr
1778 Views, 21 Replies
Hi All
Very new to CAD/CAM and returning to CNC after learning to use a sinumerik at 14 years of age (long story)
My problem is that the post for our 2005 CTX410 using a fanuc 21i and the 'fanuc turning.cps' generates a G17 code for the drilling process (using a udrill)
This cause the CNC to report a '028 ILLEGAL PLANE SELECT' at what I think is line N116.
I had to set the post type to B as type a gave an error for line N12 so the G50 became a G92.
I assume I have the model wrote.
Mike
21 REPLIES 21
Message 21 of 22
accounts7JPEJ
in reply to: mjoconr
Have you made the changes as mentioned above?
Message 22 of 22
Some Fanuc controls are setup to use G18 with polar interpolation and some using G17.  Drilling cycles do not use polar interpolation, which is why the G17 is output.  You can modify the getG17Code in your post to return G17 for polar interpolation to resolve your issue.
// Change this function ...
function getG17Code() {
  return (machineState.usePolarInterpolation || !gotYAxis) ? 18 : 17;
// To look like this ...
  return !gotYAxis ? 18 : 17;
Bob Schultz
Sr. Post Processor Developer
