& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
This must be one of the simplest scenarios but I cannot find the answer.
I have a length of stock, say X=300mm, Y=50mm,Z=25mm, say a few millimeters longer than the job (X axis). The stock Y and Z dimensions are to drawing. Holding the stock in a vice with the ends extending beyond the vice jaws I want to face off to the X dimension (300mm) machining in the Y/ Z axis. One end then the other, lifting the tool to the safe height to transition over the vice.
Is this a 2D or 3D function? I cannot see an obvious candidate for doing this
Thanks in advance
Pete
(BTW I have tried adaptive clearing but it appears to have a go at everything it can find, on the job. Tasks that are destined for later operations.)
thats just a 2D contour and you select the 2 single ends of the part. Hold ALT while selecting to pick a single entity.
As I suspected that is ridiculously simple. I was not aware of the ALT key single selection
Thank You
Pete
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
