Fusion Manufacture
Export Tool Direction along with XYZ
2 REPLIES 2
2018tkosmal
379 Views, 2 Replies
I am trying to export tool direction data (see highlighted in pic) along with XYZ data for a 5-axis milling operation on a generic machine. There are currently post processors from Autodesk able to export XYZ data, but no mention of ability to access tool direction. Is there an existing post processor, way to export this data to csv, or other quick mod to export this data out of fusion?
Thanks!
Labels (4)
2 REPLIES 2
AchimN
in reply to: 2018tkosmal
You can use the dump.cps post processor to export that data as shown in the screenshot below:
Achim.N
Principal Technology Consultant
Tomek.G
Hi @2018tkosmal,
You can use Export toolpath to simple list postprocessor.
The output coordinates are the starting position, end position, and tool orientation.
Tomek.G
Sr. Technical Consultant
