Full Error:
Error: Sketch Sketch16 has no closed profiles for NestResult
Error: Cannot get the geometries for the selected component: LS Mid Left:1/LS Mid Left. A planar face is required to be arranged.
This is a curious piece. It worked in an earlier version of the model. But I went back and straightened a few things in the T-Splines. And now I'm getting this curious error on one half of an apparently symetrical object (modelled with T-Splines mirrored and then split). The other half operates with no problems. And I haven't
I can put a hole in the curved face and it does go to the surface - but offsets to that hole in the surface (and overlaps in the full model.)
If I remove the inside faces in the original model (ie: remove the loft that performed the cut operation to create the concave surfaces) I am still getting the errors.
I did see in the original model that it was creating non-symetrical lofts based on the offsets of the symmetrical halves. I would have to select a different number of faces inside one half compared to the other half. Unsure if that matters after discovering that the error still exists when the loft that created the concave faces has been removed.
Thoughts?
Many thanks!
