Hi folks. I am trying to select a few edges in a simple part in order to create a laser job from, and it is giving an error:
Warning: One or more passes were discarded due to linking constraints. Generation completed with 1 warning(s) in 786.2ms.
I am going to be using the DXF export post, so pretty much all the setup and contour options are probably ignorable, as long as it generates paths compensated for a 0.3mm kerf.
Solved by LibertyMachine. Go to Solution.
Your part is not visible to those following that link. Could you export and share your file?
File > Export > Save to local folder. Return to thread and attach the .f3d file
Oops, I thought I had shared it. I have edited the original post and added an attachment.
Your lead-in is too large. Set it to a value of 4mm or smaller
