Error: Internal CAM kernel error. Please report through your support channel.
cadTPLWJ
cadTPLWJ
I got this message all of a sudden in the CAM section of a simple design. (Attached)
This particular Adaptive Clearing has worked and I have made a physical part from it.
Don´t know if the CAM setup is included in the .f3d file.
I was trying to make a finish pass for the top surface when this happened.
I do not know if anyone is interested in this but I followed the instruction "Please report through your support channel."
HughesTooling
One problem is you have the stock set to from solid but you do not have anything selected, for from solid you need to draw the stock as a body. After I set the stock to relative size box and setting the geometry tab like this and it works.
Mark
Mark Hughes
Owner, Hughes Tooling
cadTPLWJ
I had previously selected a solid body as stock. For some reason this was removed. I can very well have accidentaly removed it myself.
The error message however did not point in the problem direction.
You pointed out the problem correctly.
HughesTooling
I have had a body unselected on occasions when I've gone to the model work space and edited the body so that could be a reason for it unselecting.
Mark
Mark Hughes
